Pro/ToolKit reading assembly data
vvladimir
Could you please help me with the following problem.
I get geomtry (thesselation) of the part using the following code:
ProError Convert_Part(ProMdl Mdl, ProMatrix Matr)
  ProError status = PRO_TK_NO_ERROR;
  ProName WName;
  ProCharName Name;
  ProSurfaceTessellationData data;
  ProSurfaceTessellationData *Output;
  ProVector Vect, CoM;
  ProMassProperty mass;
  Pro_surf_props prop;
  ProMatrix PrevMatrix, IM, _IM;
  int n_obj, i, j, k, clr;
  char *lVerts = (char *)calloc(100000000, sizeof(char));
  char *lFacets = (char *)calloc(100000000, sizeof(char));
  char tmpVert[100];
  char tmpFacet[100];
  int offset = 1;
  status = ProMdlNameGet(Mdl, WName);
  for (i = 0; i < 4; i++)
  for (j = 0; j < 4; j++)
  PrevMatrix[i][j] = AsmMatrix[i][j];
  status = ProSolidMassPropertyGet((ProSolid)Mdl, NULL, &mass);
  fprintf(UcfFile, "  material = %s;\n", GetPartColor().c_str());
  Output = (ProSurfaceTessellationData *)calloc(10, sizeof(ProSurfaceTessellationData));
  status = ProPartTessellate((ProPart)Mdl, 0.01, 0.1, PRO_B_TRUE, &Output);
  status = ProArraySizeGet(Output, &n_obj);
  for (i = 0; i < n_obj; i++)
       data = (Output[i]);
       for (j = 0; j < data.n_vertices; j++)
            sprintf(tmpVert, "  %lf, %lf, %lf;\n", data.vertices[j][0], data.vertices[j][1], data.vertices[j][2]);
            strcat(lVerts, tmpVert);
     for (j = 0; j < data.n_facets; j++)
            sprintf(tmpFacet, "  %d, %d, %d;\n", data.facets[j][0] + offset, data.facets[j][1] + offset, data.facets[j][2] + offset);
            strcat(lFacets, tmpFacet);
     offset += data.n_vertices;
  fprintf(UcfFile, "Vertices = {\n%0s  };\n", lVerts);
  fprintf(UcfFile, "Faces = {\n%0s  };\n", lFacets);
  free(lVerts);
  free(lFacets);
  status = ProPartTessellationFree(&Output);
  return status;
I works correct. My next step is to get the same data for all parts in
the assembly. For that I use the following code:
ProError Convert_Assembly(ProMdl Mdl, ProMatrix Matr)
  ProError status;
  ProMatrix Prev;
  int i, j;
  status = ProSolidFeatVisit((ProSolid)Mdl, VisitFeat, NULL, NULL);
ProError VisitFeat(ProFeature *feat, ProError status, /**ProMatrix/*/ProAppData/**/ AppData)
  ProFeattype FeatType = 0;
  ProAsmcomp *AsmComp;
  ProMdl Mdl;
  ProMdlType MdlType;
  ProMatrix Matr;
  ProMatrix PrevM;
  ProMatrix EndM;
  int i, j, k;
       PrevM[i][j] = AsmMatrix[i][j];
  status = ProFeatureTypeGet(feat, &FeatType);
  if (FeatType == PRO_FEAT_COMPONENT)
       AsmComp = feat;
       status = ProAsmcompMdlGet(AsmComp, &Mdl);
       status = ProMdlTypeGet(Mdl, &MdlType);
       status = ProAsmcompPositionGet(AsmComp, Matr);
                 EndM[i][j] = 0;
                 for (k = 0; k < 4; k++)
                      EndM[i][j] += Matr[i][k] * PrevM[k][j];
       if (MdlType == PRO_MDL_PART)
            Convert_Part(Mdl, EndM);
      else
       if (MdlType == PRO_MDL_ASSEMBLY)
            Convert_Assembly(Mdl, EndM);
  return PRO_TK_NO_ERROR;
When I try to process the assembly from the samples [PROE_PATH\vbapi\vbapi_examples\models\drill_chuck.asm] the
program give me data for two parts of three and Pro/E / Creo closes.
It closes without any errors or warnings. It simply silently closes.
At the same time if works correct again when I create new assembly and
add there same parts from mentioned sample model if I add parts to
assembly from the assembly's folder.
Could you please give me a hint what might lead to such abnormal
program behaviour? Any suggestions and comments would be highly
appreciated.
FV
17-Peridot
17-Peridot
(To:vvladimir)
Hi all,
Vladimir,
You should question the validity of this statement:
       data = (Output[i]);
HIH.
