Pro/toolkit error startup of application failed
Emilie
I am developping a bit with Pro/Toolkit. First I did my application as spawn mode (exe) as they advice us. I have no problem with that, I compile it and register it and then it works fine in ProE 64 bits. Then I decided to do the same application but as DLL mode in order to have my application running faster but I can't get it to work :
non pb with compilation , then I register it like this :
name ProEConnectorDLL
startup dll
exec_file C:\Devel\ProEConnectorDLL\x64\Debug\ProEConnectorDLL.dll
text_dir C:\Devel\ProEConnectorDLL\text
delay_start TRUE
allow_stop TRUE
REVISION 18
end
then I launch it thanks to Tools/Auxiliary Application but when I start it I get the error message : startup_failed.JPG
Please help!
Thank you
19 REPLIES 19
akapoor
(To:Emilie)
Did you check the trail file after the application run?.
Can you send what your userinitalize looks like.
Anika Kapoor
Emilie
(To:akapoor)
Hello!
Sorry if my question seems simple but where can I find the tail file?
Here is my userinitializee :
extern "C" int user_initialize()
ProError err = PRO_TK_NO_ERROR;
ProMode mode = PRO_MODE_UNUSED;
err = ProModeCurrentGet(&mode);
if(err == PRO_TK_NO_ERROR)
if(mode == PRO_TK_BAD_CONTEXT)
printf("ProModeCurrentGet error in user_initialize.\n");
return(0);
Thank you
earnal
(To:Emilie)
I don't think trail file will help a lot... Generaly there is only a line with the same message than the error dialog...
First of all, you must check if the protk.dat paths are good in Help->System Informations->Auxiliary application Information.
If everything is OK, check if all dependancies of your dll is in the same directory.
BR,
Etienne
Emilie
(To:earnal)
I checked the path from the protk.dat and they are good. I renamed the dat file protk_dll.dat, I guess it's not a problem.
I checked the dependencies and they are all in the same directory...
Do you have a small example project ofr example? I am using Visual Studio 2008 Express. Maybe it's something in the configuration of my project, if I could compare with a working .sln it could be very helpful
Thank you a lot!
earnal
(To:Emilie)
Try with filename protk.dat instead of protk_dll.dat
Emilie
(To:earnal)
nothing changed...
earnal
(To:Emilie)
Try with a basic protk.dat:
startup dll
end
Check the path not in the protk.dat but in the auxilliary application information (after start fail).
My user_initialize function don't have the same prototype.
I have "extern "C" int user_initialize(int argc, char *argv[], char *version, char *build, wchar_t errbuf[80])".
Have you a "void user_terminate() {}" function ?
Emilie
(To:earnal)
Here is what I have in my main.cpp :
Pro/TOOLKIT includes
#include "ProToolkit.h"
#include "ProCore.h"
#include <ProMenu.h>
#include "ProUtil.h"
ProEConnector includes
return(0);
extern "C" void user_terminate()
err = ProViewRefit (NULL, NULL);
if(err != PRO_TK_NO_ERROR)
printf("error %i.\n",err);
else
printf("Terminate.\n");
void main(int argc, char *argv[])
ProToolkitMain (argc, argv);
return;
akapoor
(To:Emilie)
Can you try removing void main function ?
Emilie
(To:akapoor)
I just did. but still I get the same failed message.
LarsZiegler
(To:Emilie)
Hello Emilie,
I have testet that source code in Visual Studio 2005 with Wildfire 4.0 64-bit and it works perfect.
My settings:
Additional include path:
\ProTOOLKIT\Wildfire 4.0 M200\protoolkit\includes
\ProTOOLKIT\Wildfire 4.0 M200\protoolkit\protk_appls\includes
preprocessor:
PRO_MACHINE=36
PRO_OS=4
Lib dir:
\Wildfire 4.0 M200\protoolkit\x86e_win64\obj
lib:
protk_dllmd.lib
Greetings Lars
did you try with Visual studio 2008?
Is it possible that you send me your project, please? Maybe I did something wrong in the configuration.
LarsZiegler
(To:Emilie)
Hello Emilie,
I think the Visual Studio 2008 Express version has no support for 64-bit programming?
Isn't it???
You want to get a 64-bit dll?
Have you installed an 64-bit ProE? Do you link your projekt to the 64-bit libs of protoolkit?
You can analyse your dll with the dependency walker (64-bit version).
Or send the dll to me.
Greetings Lars
I have installed the 64 bits version of ProE and I link with the 64 bits libs of protoolkit. and the weird thing is that I don't have a problem doing an 64bits exe... But as I wanted to have better perfo I decided to do a dll and even with a very simple project I can't get it to run..
Here is my dll.
Thank you for your help
I am really wondering why I have no problem generating and using an exe but it's not ok for a dll.
Do you have any clue on this?
earnal
(To:Emilie)
What version of PTC product are you using : WF4, WF5, ProElement5, CREO1, CREO2 ?
For WF4, you must use Visual Studio 2005.
For WF5 and PE5, you must use Visual Studio 2008.
For CREO1 & 2, you must use Visual Studio 2010.
Emilie
(To:earnal)
I have WF5 and I am using Visual Studio 2008 Express.
I will try with Visual Studio 2008 (not Express).
Emilie
(To:Emilie)
I finally managed!!
I am using Visual Studio 2008 with these settings :
-include files :
proeWildfire 5.0\protoolkit\includes
proeWildfire 5.0\prodevelop\includes
- libraries files :
proeWildfire 5.0\protoolkit\x86e_win64\obj
- Runtime Library : Multithread (/MT)
- Additional Dependencies :
protk_dll.lib
wsock32.lib
mpr.lib
psapi.lib
ws2_32.lib
netapi32.lib
And this protk.dat :
NAME ProEConnectorDLL
STARTUP dll
ALLOW_STOP TRUE
DELAY_START FALSE
EXEC_FILE C:\Devel\ProEConnectorDLLPrj\x64\Release\ProEConnectorDLLPrj.dll
TEXT_DIR C:\Devel\ProEConnectorDLLPrj\Text
END
Thank you for your help guys!
Emilie
LarsZiegler
(To:Emilie)
for DLLs I use
Multithreaded-DLL (/MD)
with
protk_dllmd.lib
