Regeneration status ProSolidRegenerationstatusGet()
cshah
How to capture regeneration status (Green-Fully generated, Yellow-Needs regeneration, Red-Failed Regeneration) using
syalagudri
(To:cshah)
Object of ProSolidRegenerationStatus is enum and you will get this as return type from API "ProSolidRegenerationstatusGet"
typedef enum
PRO_SOLID_REGENERATED,
PRO_SOLID_NEEDS_REGENERATION,
PRO_SOLID_FAILED_REGENERATION,
PRO_SOLID_CONNECT_FAILED
} ProSolidRegenerationStatus;
cshah
(To:syalagudri)
thanks for the reply.
I have written code as below, where objAsmMdl read the assembly name.
after writing this code every time it shows status 2 as failed regeneration which is irrespecting to the regeneration status of the assembly. I mean if the assembly is fully generated than also the code give the value as 2.
Can you help in improving the code?
ProMdl objAsmMdl;
ProSolidRegenerationStatus regenStatus = PRO_SOLID_FAILED_REGENERATION;
status = ProSolidRegenerationstatusGet((ProSolid)objAsmMdl, &regenStatus);
if (status != PRO_TK_NO_ERROR)
 Log::WritetoLog("ITCPATPumpAutomationMain::Regeneration Status----->Failed to Regenerate",status,0);
return status;
RPN
18-Opal
18-Opal
(To:cshah)
Maybe I’m wrong, but for me you check only the status of your function call, and not the return value ‚regenStatus’
Ketan_Lalcheta
(To:cshah)
I have never faced issue for this API . It works as it should be. Do you mean to say that status of regeneration is PRO_SOLID_FAILED_REGENERATION when you say status as 2? It never says this status when model is already regenerated. In case of circular reference, status could be PRO_SOLID_NEEDS_REGENERATION, but definitely not PRO_SOLID_FAILED_REGENERATION if model is already regenerated. HIH Ketan
cshah
(To:Ketan_Lalcheta)
Issue is resolved now. Thanks for your response.
