Regenrate the model
ddhini
Regenrate the model
I have a model.I update some parameter and when i click the Regenerate Button then the model gets regenerated and displayed.But i did something in my tool ,I give input through my tool.Its affect the parameter and updates the value.Now I want to regenerate the model by J-Link.
model mode;
model=Session.getCurrentModel();
model.RegenarateRelation();
model.display();
But it wont regenerate the model.Please help me to solve my problem.Thanks in advance.
sjuraj
(To:ddhini)
Do following:
Solid solidModel = (Solid) session.GetCurrentModel();
session.SetConfigOption("regen_failure_handling", "resolve_mode");
solidModel.Regenerate(null);
session.SetConfigOption("regen_failure_handling", "no_resolve_mode");
sjuraj
(To:ddhini)
Regenerate method is allowed only for solid object. You need to cast your Model object to Solid object. Try this:
Solid solidModel = (Solid) session.GetCurrentModel(); //this will cast Model to Solid
RegenInstructions ri = pfcSolid.RegenInstructions_Create(null, null, null);
solidModel.Regenerate(ri);
ddhini
(To:sjuraj)
i exactly use the code that you suggest .But it is not working . Don't know what the problem.
sjuraj
(To:ddhini)
there must be set regen_failure_handling resolve_mode in the config.pro
If you do not want to keep resolve_mode option after regeneration change it to no_resolve_mode using method session.SetConfigOption("regen_failure_handling", "no_resolve_mode"); after regenerating by j-link app
by the way, you do not have to create regen instructructions, just pass null as parameter in Regenerate method
ddhini
(To:ddhini)
Can you please explain briefly .I can't understand
sjuraj
(To:ddhini)
Do following:
ddhini
(To:sjuraj)
Thanks a lot skvarka juraj‌.It works fine.
