Toolkit Application Menu Button Text Not Changing with Resource File
DB_10804535
I am trying to modify the text in pt_install_test to have a different button name. My .dat has text_dir set as just ./pt_install_test. Inside ./pt_install_test, I have been editing ./pt_install_test/text/usascii/msg_user.txt, such as
-Install Test Label
-Install Test TEST NEW VALUE
but this change is not being reflected in the menu. I expected that this did not need a rebuild, but I've tested with rebuilds as well and the text is not changing. I am confused where it is even getting this old value from at this point.
Hi DB_10804535
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) or a short video to better understand what you are trying to do in your process.
This will increase your chances to receive meaningful help from other Community members.
Vivek N
Community Moderation Team
