Toolkit or JLINK notifier for any edits to model which does not reset the undo/redo buffer
rstreet
6-Contributor
Toolkit or JLINK notifier for any edits to model which does not reset the undo/redo buffer. This is so we can warn the user that the model needs to be checked out of source system.
0 REPLIES 0
