Update operation origin in SMARTElectrode interactively
FlorianHammrich
From SMARTElectrode 12.0.1.3 on it is possible to change the zero points of the electrode assembly interactively in Creo Parametric. Two methods are now available for editing
  1. Redefinition using the user interface
  2. Interactive change in Creo Parametric
With the direct change, either the referenced coordinate system or the zero point can be redefined directly. In both cases SMARTElectrode automatically detects the change of the zero point definition and updates the position data of the electrodes accordingly.
The following video shows the usage of the improvement in detail:
And if you want more informations:
https://www.buw-soft.de/en/2019/11/18/automatic-update-when-operation-zero-is-changed/
Florian Hammrich
B&W Software GmbH
0 REPLIES 0
