I am ready to engrave some words on a surface using extrude function. The code list below, but seems the specified font did not work. I checked the feature created by this function, the font is still font3D. How can I use other font?
One possibility may be that the font is not stored in the proper location to be called. Creo stores TTF in a directory and not in models. Is the font you are referencing saved in the font directory and loaded?
Hello @WP_14104464,
It looks like you have a response from our community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Sorry for a long time delay.
In fact, the problem has been troubling me along.
I checked the support info below:
https://support.ptc.com/help/creo_schematics/r9.0/en/index.html#page/schematics/install_guide/c_sysadmin_7.html
It seems Creo can use fonts provided by PTC, and other ttf fonts with settings of pro_font_dir.
I tried several ways to solve the issue.
1, use CG Omega in the table, and switched the name like "cgomg", "CG Omega", or "ccgomg.ttf", no works.
2, set pro_font_dir as C:\Windows\Fonts\, and then set windows font name , like "simhei", no works either.
No progress yet.
