Axeda Connected Configuration Items Create/Read/Update
No ratings
The following script is a component of the Axeda Connected Configuration (CMDB) feature.  It is used to provide configuration data for controlling package deployments via Connected Content (SCM).
ConfigItem_CRU.groovy
*Takes a POST request, not parameters
import static com.axeda.sdk.v2.dsl.Bridges.*
import com.axeda.drm.sdk.scripto.Request
import com.axeda.services.v2.ConfigurationItem
import com.axeda.services.v2.ConfigurationItemCriteria
import com.axeda.services.v2.AssetConfiguration
import com.axeda.services.v2.ExecutionResult
import groovy.json.JsonSlurper
import net.sf.json.JSONObject
import groovy.xml.MarkupBuilder
* ConfigItem_CRU.groovy
* Reads in json from an http post request and reads, adds, deletes or updates Configuration Items.
* @note this parses a post and does not take any additional parameters.
* @author sara streeter <sstreeter@axeda.com>
def contentType = "application/json"
final def serviceName = "ConfigItem_CRU"
def response = [:]
def writer = new StringWriter()
def xml = new MarkupBuilder(writer)
try {
    // BUSINESS LOGIC BEGIN
    def assetId
    def validationOnly
    def validationResponse = ""
    List<ConfigurationItem> configItemList
    if (Request?.body != null && Request?.body !="") {
        def slurper = new JsonSlurper()
        def request = slurper.parseText(Request?.body)
        assetId = request.result.assetId
        validationOnly = request.result.validationOnly?.toBoolean()
        if (request.result.items != null && request.result.items.size() > 0){
            configItemList = request.result.items.inject([]) { target, item ->
              if (item && item.path != "" && item.key != "" && item.path != null && item.key != null){
                    ConfigurationItem configItem = new ConfigurationItem()
                    configItem.path = item.path + item.key
                    configItem.value = item.value
                    target << configItem
                target
      if (assetId != null) {
              def asset = assetBridge.find([assetId])[0]
            AssetConfiguration config = assetConfigurationBridge.getAssetConfiguration(assetId, "")
              def itemToDelete
                if (config == null) {
                    createConfigXML(xml)
                    AssetConfiguration configToCreate = assetConfigurationBridge.fromXml(writer.toString(), asset.id)
                    ExecutionResult result = assetConfigurationBridge.create(configToCreate)
                    AssetConfiguration config2 = assetConfigurationBridge.getAssetConfiguration(asset.id, "")
                    config = config2
                    itemToDelete = "/Item"
                if (configItemList != null && configItemList?.size() > 0){
                List<ConfigurationItem> compareList = config.items
                def intersectingCompareItems = compareList.inject(["save": [], "delete": []]) { map, item ->
                    // find whether to delete
                    def foundItem = configItemList.findAll{ compare -> item?.path == compare?.path && item?.value == compare?.value  }
                    map[foundItem.size() > 0 ? "save" : "delete"] << item
                    map
              intersectingCompareItems.delete = intersectingCompareItems.delete.collect{it.path}
              if (itemToDelete){
                intersectingCompareItems.delete.add(itemToDelete)
                def intersectingConfigItems = configItemList.inject(["old": [], "new": []]) { map, item ->
                    // find whether it's old
                    def foundItem = compareList.findAll{ compare -> item?.path == compare?.path && item?.value == compare?.value }
                    map[foundItem.size() > 0 ? "old" : "new"] << item
                    map
                assetConfigurationBridge.deleteConfigurationItems(config, intersectingCompareItems.delete)
                assetConfigurationBridge.appendConfigurationItems(config, intersectingConfigItems.new)
              def exResult = assetConfigurationBridge.validate(config)
              if (exResult.successful){
                    validationResponse = "success"
                    if (!validationOnly){
                        assetConfigurationBridge.update(config)
                else {
                    validationResponse = exResult.failures[0]?.details
            response = [
                assetId: assetId,
                items: config?.items?.collect { item ->
                def origpath = item.path
                def lastSlash = origpath.lastIndexOf("/")
                def key = origpath.substring(lastSlash + 1, origpath.length())
                def path = origpath.replace("/" + key, "")
                path += "/"
                        path: path,
                        key: key,
                        value: item.value
                validationResponse: validationResponse
        else {
            throw new Exception("Error: Asset Id must be provided.")
catch (Exception ex) {
      logger.error ex
  response = [
          error:  [
                  type: "Backend Application Error"
                  , msg: ex.getLocalizedMessage()
return ['Content-Type': 'application/json', 'Content': JSONObject.fromObject(response).toString(2)]
* Create the Success response.
* @param xml : The xml response.<br>
* @param info : If this is set to "1" the info element will be included in the response.<br>
* @param infos : Collection of information to include within the info element of the response.<br>
private void createConfigXML(xml) {
    xml.Item()
Comments
Thanks for this topic.
I have one question :
  • How can I change the HTTP status Code of the response ?
‎May 12, 2016 09:31 AM
Labels (2)
