This project will introduce various Chart Widgets. Following the steps in this guide, you will learn how to graphically represent multiple data points simultaneously. We will teach you how to utilize the Pie, Label, Proportional, Bubble, Time Series, and Event Charts. NOTE: This guide's content aligns with ThingWorx 9.3. The estimated time to complete ALL 3 parts of this guide is 60 minutes.
As an IoT application developer, there are times when you want to display multiple data points simultaneously. In this situation, it is often helpful to make use of one of the various Chart Widgets.
This guide will discuss the following Chart Widget options:
*Old widget = no web component replacement
Before you can display this information in your UI, you need to first configure the ThingWorx system to store those values. For the time-series charts (including both the Line and Event Charts), you need to store information in a time-series friendly manner. In this case, we’ll use a Value Stream to store Property value changes. We’ll use an Info Table (similar to a spreadsheet) to track the values for the non-time-series charts (Pie, Label, Proportional, and Bubble).
Many data structures in ThingWorx require a Data Shape to format their values. This is true for a Stream, a Data Table, and an Info Table. We'll be using an Info Table in this example.
NOTE: Any time you use an Info Table, you must first define a Data Shape.
9. Click the "Check with a +" button for Done and Add.
10. In the Name field, enter Label.
11. Leave Base Type as the default of STRING.
12. Click the "Check with a +" button for Done and Add.
13. Repeatedly add additional fields, each with a Base Type of NUMBER, until all of the following Field Definitions have been entered:
Note that you'll want to click the "Check" button for Done after entering the last definition.
14. Click Save.
An easy way to record changes to a Thing Property is via enabling the Logged functionality.
However, without a place in which to log the changes, logging the Property does nothing.
One way in which to create a storage location for Property changes is a Value Stream.
Click here to view Part 2 of this guide.
