How to enable ThingWorx Performance Advisor to better monitor usage?
No ratings
Applies To
  • ThingWorx 7.2+
Description
  • How to enable ThingWorx Performance Advisor
Resolution
  • In the ThingWorx Composer, go to Systems > Subsystems, select the PlatformSubsystem and choose Configuration
User-added image
  • In the Metrics Reporting Service Configuration
    • Select the "Enable Metrics Reporting" checkbox to activate Performance Advisor reporting
    • Enter your current PTC credentials (username and password) for either the customer support portal or the developer portal
  • After providing those details, use the Request button to request an Authorization Key.
  • Customer Number and Name will be filled automatically and an Authorization Key is generated which allows the server identifying itself to the PTC environment. Those fields are read-only.
  • ThingWorx is now ready to send Performance Advisor data and metrics to PTC
User-added image
Related
‎Sep 28, 2017 02:20 PM
Labels (2)
