CLX ETH Redundancy Option
Invalid_String
If my KepServerEx V6 instance has two separate network connections to a pair of EN4TR com cards in a CLX rack,  This is to give me redundant com paths to the critical systems.
Is there a way to configure them in a redundant\failover architecture within KepServerEx?
I know this can be done with an external router but I was hoping there was a native solution.
@Invalid_String
The link tag function would not work since there would be a secondary path. The two channels cannot be named the same and the Link Tag does have the functionality to recognize the secondary path.
*Chris
@Invalid_String
The functionality you have described could possibly be done with Media Level Redundancy. Here is a link to the Kepware knowledge base article that covers the use of Media Level Redundancy:
Article - CS304183 - Media Level Redundancy feature with PTC Kepware Products
You can your MyKepware login credentials to access the article.
I also recommend opening a support ticket with the Kepware team to analyze your specific architecture. Here is a link to the login page where a ticket can be logged:
Log In | My Kepware
*Chris
@cmorehead
Are linked tags supported with Media Level Redundancy?
I have a large number of linked tags between an OPC DA server and this CLX ETH instance.
IF a failover were to happen, would the linked tags still function?
Since mirror tags are created on the secondary device, I suppose it is possible that the linked tag read/write request referencing the primary tag would just use the secondary path.
@Invalid_String
*Chris
That is disappointing, but I'm happy to know it up front so no time is wasted in testing.
I may just setup two linked tag groups and two individual channels with one CLX device in each.  Each linked tag group would reference a single CLX Eth instance.
The failover would be a manual operation to disable one linked tag group and enable the other, but at least i would have my redundant paths.\
Thanks for the info.
