.NET Version Compatibility with KepServerEX
ST_8967881
I have KEPServerEX 6.17.269 installed. I ran Nessus Vulnerability scanner and it appeared that .NET 6.0 is installed on PC. I think that KEPServerEX uses .NET.
The reccomended remediation is to install .NET version 8.0. I wanted to ask if KEPServerEX 6.17.269 is compatible with .NET version 8.0? Is there any page that I could see which versions of .NET is suported by which version of KepServerEx?
HI,
  • There is no dependency on the .NET version for using KEPServerEX/ThingWorx Kepware Server (KSE/TKS)
  • .NET Framework can be upgraded safely
Note: OPC UA components are dependent on the .NET Framework and yes they are compatible with .NET version 8.X (Windows x86 version).
HI,
