Omron CP2E with KepserverEX V6
corta19
Hi, I tried to connect between KepserverEx V6 with my omron CP2E-N but when I read the value in OCP client it always return Bad quality. I don't know why, and where I went wrong. Below is my config. Please help me. Thank you very much
@corta19
Please take a look at the knowledge base article in the following link:
Article - CS370609 - How to connect to OMRON CP1L and CP2E in PTC Kepware products
You can use your my kepware login credentials to access the article.
I recommend opening a support ticket with the Kepware Technical Support team if article does not resolve your connection issue.  Here is a link to the login page where a support ticket can be opened:
Log In | My Kepware
*Chris
corta19
(To:cmorehead)
Thank you for your information, I have already read the basic link you gave me, but it seems doesn't work.
I had sent the support ticket. I hope it can work
