All,
I am new to machining in more than 3 axis andneed help setting up a roughing and finishingsequence to machine the area shown in the PDF file. I would like to rough the groove down the center using a flat end mill in several cuts and then finish each wall at full depth. I am using Creo 1.0 and the machine is a Mazak Variaxis 630. A STEP file is also attached. In addition, are there any special options in GPOST thatI shouldwatch for that pertain to this machine or 5 axis milling in general?
Thanks in advance for your time.
Jim
