Dear partners,
I am working in a graduation project with PTC Creo Parametric, it is about a machine for make torsion springs, the shape of these is like a Z, I would like to know if there is any solution from PTC for this job, I need to make a simulation of torque motor, I need to simulate the deformation wire for find the maximum torque motor, I have not been able to find a tool that allow me make this simulation,
I will be grateful if you my dear partners can collaborate me with a solution, or tips about How can I solve the problem
Are you trying to find the maximum torque needed to bend the wire into the final spring shape?
Hello Andrés,
Would you have a view of your torsion spring Z
There is a demo PTC Simulate the deformation of a staple piece, but I can no longer find it.
Attached is a view of a torsion spring in what I think.
Sincerely.
Denis.
I am grateful for your help, thanks a lot
I need to simulate and plot the torque motor in throughout its career (making the torsion spring), I need to justify the calculations of torque motor, I have the assembly in Creo Parametric 2.0, I wolud like to know if is there any tool that let me simulate a deformation, this means for example if I apply a Torque in a any crowbar, I would like to see the deformation and torque motor y all movemente
Thanks you so much for your collaboration
