Hello
Does anyone know how to change the window size of EMX parameters by default when I want to insert a component?
The window is smaller than it should be ...
I send attached two images; one as it is and the other as it should be. When I want to insert a component it looks like the first image and after changing a parameter the window gets bigger as shown in the second image
Thanks in advance
@phenriques wrote:
Hello
I send attached two images; one as it is and the other as it should be. When I want to insert a component it looks like the first image and after changing a parameter the window gets bigger as shown in the second imageThanks in advance
if you provide information what Creo and EMX version you are using then I hope @tschneyer will answer you question.
Hi ,
I,m using Creo 3.0 M190 with EMX 10 M011 ...
thanks
Paulo Henriques
Hello phenriques,
This problem was already fixed. Please update to the latest release.
Kind Regards,
Thomas
