Communication from pc to cnc machine
ptc-5142642
I'm struggling to get through the programs conducted in Pro_E
when wanting to load the machine does not recognize me
machine is a V414 monitor Mazatrol M32B already have the wire set I SURFCAM DNC communication and ADVANCE anyone of you will have the manual to make sure the steps are correct on the screen of the machine to RECEIVE the program?
You are posting in a subspace of the Mathcad section of this forum. Obviously its not a question about Mathcad. Better chance for a qualified answer if you post where it belongs to.
Sorry no hubique good site where I put this question
thanks
Guess the right place to ask is the main Creo section here: http://communities.ptc.com/community/post!input.jspa?containerType=14&container=2023
Thanks for catching this Werner, I've moved this discussion into the relevant community.
Thanks friend
