Hi, how i can get the postprocessor for DMG Mori 5 Axis Machine with Siemens 840 control.
Hi @MS_10903726
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry.
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
This will increase your chances to receive meaningful help from other Community members.
Best regards,
If you did a search you'd probably find the following:
https://www.ptc.com/en/support/article/CS54723
and
https://www.ptc.com/en/support/article/CS314941
You probably won't find anyone, unless you are very lucky, who has a suitable post for your specific machine. You might be able to take some other existing post processor and modify it to suit you and your control type.
Otherwise, you might have to ask the professionals at a place like Austin NC to help you. I have heard others on here recommend them for such things in the past.
Thank you, is there have any expert who can help to modify the postprocessor.
Here's a similar inquiry from the past.
https://community.ptc.com/t5/Manufacturing-CAM/Does-anyone-has-a-4-Axis-Post-processor/m-p/943733
People on these forums, including me, are not going to write a postprocessor for you. As discussed in the linked past question, you need to know a lot of specific things about the machine it is for. Startup sequence, preparations for a tool change, etc. No one is going to take the responsibility for doing this on a discussion board. The failures can be terrible.
Hi @MS_10903726,
Please note that industry experts also review the replies and may eventually accept one of them as solution on your behalf.
