Will the production machining option in Creo give me the ability to post process my models in manufacturing mode to a .tap file. Will it also post process to g-code and does it come with the basic drivers to post to g-code?
Dustin,
Yes the production machining has the ability to post process files to G Code using G Post from Austin NC. All the manufacturing modules have the ability except for expert machinist as I found out a while ago.
There is a large assortment of pre built posts in the support portal that you can use or build your own using them as starting points.
Steve L.
Dustin,
Steve L.
The large assortment of pre-built posts are located here: http://support.ptc.com/cs/cs_27/howto/ncgp4905/ncgp4905.htm correct?
Thanks!
Those are the ones. can't you find what you are looking for?
You can also check out the one that Austin N.C. has, this may be more up to date.
Those are all fine, was just checking if that was the full library! Thanks so much
