Feed Rate
pesau-2
Feed Rate
hi,
for all my NC program I get feed rate as F1  even though I enter as Cut_feed = 100, can anyone please suggest what change to be made in GPOST.
There is another place you need to set the F register format.  Since the F is used for several things each feed rate mode has its own format.  For UPM it is set on this dialog box.  The places left of the decimal need to match the Maximum value allowed.
Fred
Using the Option File Generator ->File Formats->MCD File, select "F" row-> Edit Selected Address, and adjust your formatting.
ex:
Josh
hi Josh,
Thanks for the reply,
the formatting setting was ok,
But still I get F1 only
Fred
Hi Fred,
Thank for the support , now its working fine.
erosa
1-Visitor
(To:pesau-2)
Hello Paulson Esau!
Could you share this post processor 5 axes heidenhain with me?
Thank you very much in advance.
