Fill routines for Fixture Offset and Tool length offset
GeorgiosLaboura
Dear Pro/Gurus I need your expert help.
I need two fill routines,
First to add the line G0 X0 Y0 C0 B0 after the fixture offset (set / ofsetl,
54)
and the second to read the tool number of Loadtl / 1
and put it along with Spindle command with the format G43.4 H1 S...M3
Before
T1
M6
G54
S1100M3
G1G94X241.131Y0.0Z-66.0C0.0F9999B90.0
X162.0
X158.0F100
After
T1
M6
G54
G0X0Y0C0B0
G43.4H1S1100M3
X162.0
X158.0F100
T.I.A
Georgios Lambouras
C.N.C programmer
Gpost forces tool length offset number (G43.4) along with (H) register
to be output with the next Z value.
Is there a fill routine that reads the tool number (LOADTLl / 1) put it
together with spindle command
composing the following format?
G43.4 H1 S1100 M3
Or it can be output right after the spindle command.
S1100 M3
G43.4 H1
Before
T1
M6
G091 G28 Z0.0
G090
G54
G0X0.0Y0.0C0.0B0.0
S1100M3
G1G94G43.4X241.131Y0.0Z-66.0C0.0F9999H1M8B90.0
X162.0
X158.0F100
X241.131F9999
After
T1
M6
G091 G28 Z0.0
G090
G54
G0X0.0Y0.0C0.0B0.0
G43.4H1S1100M3
G1G94X241.131Y0.0Z-66.0C0.0F9999M8B90.0
X162.0
X158.0F100
X241.131F9999
NCL FILE
$$* Pro/CLfile
$$-> MFGNO / T15_MFG
PARTNO / T15_MFG
$$-> FEATNO / 148
MACHIN / UNCX01, 32
$$-> CUTCOM_GEOMETRY_TYPE / OUTPUT_ON_CENTER
UNITS / MM
LOADTL / 1 $$-> CENTER DRILL 6MM 90DEG
$$-> CUTTER / 6.000000
SET / OFSETL, 54
$$-> CSYS / 1.0000000000, 0.0000000000, 0.0000000000, 0.0000000000, $
0.0000000000, 1.0000000000, 0.0000000000, 0.0000000000, $
0.0000000000, 0.0000000000, 1.0000000000, 0.0000000000
MULTAX / ON
INSERT/G0 X0.0 Y0.0 C0.0 B0.0$
SPINDL / RPM, 1100.000000, CLW
COOLNT / ON
FEDRAT / 9999.000000, MMPM
GOTO / 241.1307, 0.0000, -66.0000, $
1.00000000, 0.00000000, 0.00000000
GOTO / 162.0000, 0.0000, -66.0000, $
FEDRAT / 100.000000, MMPM
GOTO / 158.0000, 0.0000, -66.0000, $
T.I.A
Georgios Lambouras
C.N.C programmer
_____
