what is the difference between Gpost and option file generator can anyone explain????
Hi there - I renamed the headline of your discussion to "Gpost vs option file generator?" to give others some more context on your question. Good luck!
GPost is the Post-Processing solution for the CAM side of Pro/E, Creo.
The option file or FIL file is a component of Gpost that is essentially a Gpost Macro that allows the user
to completely customize the output of a given post-processor.
While Gpost is a decent soltuion, CAM-POST from ICAM is a superior solution that's easier to use and customize.
