Hey everybody,
When i place ejectors using EMX, the cut which is generated is always very close or coincident with the ejctor shaft. See pic:
This makes it difficult to add a champfer in the hole.
I would like the distance from center of ejector to rotfix surface to be bigger. See below pic:
Where can i find the parameter file, from which i can increase this distance??
Best regards Clement
Creo3.0 M040
EMX9.0 F012
Hello Clement,
If you have a look to the Component Dialogs bottom area you will find the dimension OFF which is responsible for your described issue.
In the last column you will also find a RULE which presdefines the OFF value depending on the DM3 Diameter: In this case 0.5*DM3.
This rule is set up in the udf_data.txt file, which can be found here: <emx_intall>\components\mm\ejector\udf
In my example I assemble an ejector pin which uses the template: "ejector_2.prt"
In the udf_data.txt all udfs used for the template type "ejector_2.prt" defined in the Section EMX_UDFS (See picture below)
You will find the udf EJP_CB_FIX1_2 which ist responsible for the cut out of type Rotfix1
The rules for this UDF are defined in the udf_data.txt a bit further bleow in the the section EMX_UDF_VALUES
You can now either change this rules to maybe to 0.6*DM3 or what ever you like.
Be aware that if you install a new blank EMX Version all these cahnges will be reset to default.
You can use alternativly set the Windows enivroment variable EMX_USER_CONFIG_PATH to point to a custom EMX configuration path there you can place the configuration and the components folder. I recommend to track your changes to the config otherwise future users wont now what was changed and this can cause unexpected behavior.
Thomas
Thanks for your feedback Thomas! Great, just the information i needed.
Regards Clement
