How to set Manual Cycle - PROBE_CYCLES
ptc-296815
8-Gravel
Hello, I am using CREO 5 - manufacturing, I am trying set probe in Manual cycle - CL Command - Menu - PROBE_CYCLES.
Has anyone work with this?
Thank you for the help
Civodul
(To:ptc-296815)
Attached an example
Hope this helps
7 REPLIES 7
Hi ptc-296815,
Thank you for your question.
I’d like to recommend to bring more details and context to your initial inquiry
It also helps to have screenshot(s) to better understand what you are trying to do in your process.
This will increase your chances to receive meaningful help from other Community members.
Vivek N
Community Moderation Team
Civodul
(To:ptc-296815)
This inspection method is not easy to use, no graphics available. I created probing cycles (UDF) using the trajectory function, this method displays the path.
Thank you for the advice.
Is it possible to send me the UDF?
Civodul
(To:ptc-296815)
It's better to create your own UDF.
You can add your own inspection cycle, PPRINT, PPWORD ...... and customize your post processor.
OKAY,
How do you define where and what the probe is supposed to measure?
Civodul
(To:ptc-296815)
Attached an example
Hope this helps
Thank you very much !!! 😉
