Impeller machining _ vericut simulation including roughing tool path
ParagVichare
8-Gravel
Hurco VM10ui with Winmax 9 also supports programming with tool vectors, thus makes the NC program independent of any particular machine configuration. We are developing a post-processor in Creo 2 (G-Post) for generating a tool vector NC file rather than XYZAC format. Some case studies are planned; one example is impeller machining.
0 REPLIES 0
