Play Path
pgf545
7-Bedrock
Play Path
We just switched to Creo 2 and I am struggling with play path. I used to be able to do play path, pick the file name and a it would open a dialog box that I could control the speed. It will still open the box if I go through the Process Manager. It will still run my CL file but I cannot control the speed so it goes real slow.What am I missing?
Thanks Bernie
NickMihelich
(To:pgf545)
oh i understand now you can also highlight just the sequences you want in the model tree and play those.
jverheyen-2
(To:pgf545)
Bernie,
I think that the cutting feed is too slow.  Maybe you made a mistake by defining the "cut data" for you tool and you entered 0.1 mm/min in stead of 0.1 mm/tooth.
Then the feed is very slow and you can not accelerate it enough by the sliding bar.
Jef
NickMihelich
(To:pgf545)
Instead of play path from a CL file move over to the model tree right click on the operation and click play path.  That will allow you to control your speed with the slider.
Thanks Nick, I have been doing that with no issues, but sometimes I will only do a CL file for a few sequences (set) and that is where the issue is. I used to be able to do it in earlier versions but I guess Creo2 doesn't do that anymore.
NickMihelich
(To:pgf545)
Yeah that would work, didn't even think about that.... Thanks for the help
NickMihelich
(To:pgf545)
Glad to help.  I really like that option when i need to run vericut on just a few sequence to check for leftover material.
