How do I remove the errors Tool parameter TOOL_ROUGH_SPINDLE_RPM (used in relation): value undefined. and Tool parameter TOOL_ROUGH_AXIAL_DEPTH (used in relation): value undefined.
I already do the following...
1. In the Tool Manager I add spindle speed and feed and radial and radial depth.
2. In the parameters I remove any relations with these variables.
I've taken a couple screen shots of some of my dialog box travels. I've been wanting to understand machining parameters better. Some things I learned:
Check if cutting data for the material of the stock prt is defined, if not this errors will occur.
