Hi Guys,
I am making a copy mill surface in a manufacturing assy & using the Fill holes/surfaces option to fill out certain contours. I am not able to change the size (vertical) of options tab whether I keep it docked or make it independent of the window.
As you can see it only shows two contours at one time, after part file has been changed I need to modify 5 contours out of 16 & have to keep on scrolling to find out which holes are out of date. Am I missing some config option to be able to change the size of tab or PTC never gave us any option to change it?
Regrads
Pushkar
