non apre i file di fabbricazione
AC_10041462
I am using Creo Parametric Release 2.0 and DatecodeM040
abbiamo trasferito la versione da un vecchio pc a questo, ma la parte di manufacturing non funziona e non apre neanche i file di fabbricazione
Here are the errors that I faced
Hi @AC_10041462
Thank you for your question!
I’d like to recommend to bring more details and context to your initial inquiry. For example:
  • How did you transfer Creo Parametric and its files from the old PC to the new one?
  • What specific types of manufacturing files are you trying to open (e.g., .ncl, .mfg)?
  • Are there any specific error messages or codes shown when trying to open the manufacturing files?
Please add screenshot(s) to better understand what you are trying to do in your process.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
This will increase your chances to receive meaningful help from other Community members.
Here's what a good question for Creo looks like.
Thank you for your participation and please let me know if you need further assistance!
Best regards,
Catalina
PTC Community Moderator
PTC
It has been many years since Creo 2.0 and licensing has changed, but the basic concept is the same.
There are a number of things I can guess, based upon the information you gave:
(1) Did you properly set up the license server when you changed computers? The license software, FlexLM, relies on the correct Host ID for the computer it is being run on. You don't indicate whether you are running with a locked license or a network license, so maybe this isn't relevant, or maybe it is.
(2) When you installed Creo on the new computer, did you correctly configure the modules that are going to be used when you start the program? By default, if I remember correctly, it will include Creo, but the manufacturing module has to be added to the configuration. I think this can be checked/updated with a program called "reconfigure.exe", usually located somewhere like "C:\Program Files\PTC\<Creo Version>\Parametric\bin" where "<Creo Version>" is something like "Creo 2.0" or whatever they're using for your specific version.
Keep in mind that this is a very old version of Creo and not officially supported by PTC anymore. I believe they will help with licensing things, if you have permanent licenses and such, but any other technical support is not likely.
