Hi- that is fantastic in MathCADPrime. Good to know since I have a personal copy at home. However, the version we use at work is MathCAD 15.0! I did not see the same type of option under the >Insert menu, nor when I opened the "Matrix" tools.
Well son of a gun! I found how to use the insert matrix toolbar. I hadn't thought to enter a 0 for the column. I was leaving it blank. Thanks for leading me to the solution. Please close the support call.
