Sure , there is a way to change it. But. regarding such branching:
• Mathcad supports only IF and OTHERWISE
• Prime supports IF, ELSE, ELSEIF and ALSOIF.
(In all cases a 'THEN' is implied between the condition and the statement at the end of the line.)
Note that I do not consider RETURN as part of an IF... branch. RETURN provides its argument (whatever follows it) as an unconditional result of the function. It can be used as an expression in an IF construct, but also in a WHILE or FOR construct, and (preferably) at the (normal) end of the function.
I would assume that ELSE is a correct replacement of OTHERWISE, but it may depend on the structure of your program. Can you post the file(s) or at least the snippets, both from Mathcad and Prime?
Hi @EC_14511170,
Anurag
