请问怎么用mathcad画圆图,或者画二元二次方程的图形
nlan
大师:请问怎么用mathcad画圆图,或者画二元二次方程的图形
-MFra-
21-Topaz II
(To:nlan)
您好,您应该咨询您MATHCAD的帮助,还有其他类型的图如何使用饼图许多例子,和。
问候。
F. M.
24-Ruby V
(To:nlan)
Its unclear to me which type of plots you are actually looking for - Google translate did not really help to find out what "two yuan quadratic equation graphics" actually means. So it would be better if you provide some example pictures showing what you want to achieve.
If you are looking for something like pie charts, then you are using the wrong software, I fear. While its possible to create pie charts using some programming (examples were posted here in the forum from time to time) , the easy of use and quality in no way would compare to a spreadsheet program.
Werner
RichardJ
. "Binary quadratic equation". Google translate does not do a great job with Chinese. Neither does Bing translate. So using both is often the best approach.
RichardJ
(To:nlan)
Is this what you are looking for?
