3D Matrix
h_nas
3D Matrix
I would like to start using 3D matrix in Mathcad Prime, but it is not available, any advise what is the alternative, if there is any?
StuartBruff
23-Emerald II
(To:h_nas)
You can use the nested arrays to emulate multi-dimensional arrays (MDAs). I wrote an experimental MDA library, which had a reasonable degree of functionality, in Mathcad 11 just to demonstrate what was possible.
What functions / operations do you want to do on arrays.
Stuart
h_nas
(To:StuartBruff)
Sorry for being late in my response to your question!!
I have load of data, each set has a (kind of the same relation) to the other, and so on. If I can put these data into three dimensional matrix, and also plot them in 3D graph, I think the result (contour curves) I will get will gives more understanding to these parameter as a whole, instead of the individual relation between them!!!!!!
What do you think! doable or not?
Hinnd
RichardJ
(To:h_nas)
So you have two independent variables and one dependent variable? If so, create a nested matrix that contains three matrices of X, Y, and Z coordinates. You can plot that directly
One example of the work with 3DMatrix / Nested Array by a spline interpolation:
http://twt.mpei.ac.ru/ochkov/Mathcad_12/4_04_4D_Spline.png
