[API: VBA] How do I get the output from Mathcad worksheet?
yoohooos
11-Garnet
Hi All,
I would like to obtain a value of a variable from my worksheet. Let say my worksheet has x:=1 and y:=x+1=2. What function can I use to get the y value? I was trying with Worksheet.OutputGetRealValue(&As)("y") but I got an error instead. The following is my code:
Sub test01()
    Dim WS As Ptc_MathcadPrime_Automation.Worksheet
    Dim App As Ptc_MathcadPrime_Automation.Application
    Set App = New Ptc_MathcadPrime_Automation.Application
    FileName = Application.GetOpenFilename(MultiSelect:=False)
    Dim conNum As Integer
    i = 22
    conNum = Cells(i, 7)
    Do While Cells(i, 1).Value <> ""
        '' inputs
        Set WS = App.Open(FileName)
        Call WS.SetRealValue("#", Cells(i, 7), "")
        Call WS.SetStringValue("M1", Cells(i, 2))
        'Call WS.SetStringValue("M2", Cells(i, 4))
        Call WS.SetStringValue("M3", Cells(i, 3))
        Call WS.SetStringValue("M4", Cells(i, 1))
        Call WS.SetRealValue("D2", 3, "")
        Call WS.SetRealValue("D3", 3, "")
        Call WS.SetRealValue("D4", 3, "")
        Call WS.SetRealValue("D1", 3, "")
        Call WS.SetRealValue("P1", Cells(i, 5), "kip")
        'Call WS.SetRealValue("P2", 10, "kip")
        Call WS.SetRealValue("P1", Cells(i, 6), "kip")
        Call WS.SetRealValue("T1", Cells(i, 8), "in") '' need to be added
        '' check all checks
        WS.ResumeCalculation
        If WS.OutputGetStringValue("check1") <> "OK" Then
            Debug.Print ("check1:= not ok")
        End If
        Do While WS.OutputGetStringValue("check2") <> "OK"
            N = WS.OutputGetRealValue("D2")
            D2 = CDbl(WS.OutputGetRealValue("D2"))
            Call WS.SetRealValue("D2", D2 + 1, "")
I would like to manipulate D2 value, how do I do that?
Also, is it correct how I use OutputGetStringValue function? the "check2" in my worksheet is "check2="OK""
Thank you very much!!
First express y as a simple display value:
   y=
This will display y=4
highlight it and select Input/Output | Integration | Assign Outputs
A small blue box with the title Out will display around y=4
Note it is the first output and I have manually changed the alias text to y
Dim y As String
Dim y_val As Ptc.MathcadPrime.Automation.IMathcadPrimeOutputResult
Outputs = WS.Outputs
y = Outputs.GetAliasByIndex(0)
y_val = WS.OutputGetRealValue(y)
   y=
Dim y As String
y_val has three members
y_val.ErrorCode      an int32
y_val.RealResult     a Double
y_val.Units              a String
So, we refer to output by index in the I/O list and not alias name?
You can use either index which simply returns the alias or you can use the
alias
thank you very much!
For me, this only work when
Set y_val = WS.OutputGetRealValue(y)
