I want to test a Prime 2.0 worksheet in Prime 3.0 to see if it works. After saving I can't open it in Prime 2.0. Prime 2.0 says "the file type is not supported. See Logfile ...". But I can't find the logfile. The path does not exist. But in 3.0 I can reopen it. I want have the file combatible to Prime 2.0. What can I do?
Forget about the logfile.
Prime2 cannot read Prime3 files and
Prime3 cannot write Prime2 files.
So ridicoulous it may sound - if a file is in Prime3 format there is no way to convert it to Prime2 format. Thats PTCs interpretation of user friendly ease of use. Solution: Don't use Prime.
... and go to a monastery.
