Consider that, I have a data based upon the below image and I`d like to integrate that data with Creo so that I could sync up both.
Now, "Number of Active Coils: Nc:=1" is assigned as input and the "Diameter of the wire: dw:=1mm" is taken as output.
The issue I`m getting is that, I`m able to change the value of output as many time possible, but once if I assign a value as an input, it indirectly gets locked... Changing that value is impossible.
What could be the reason for this? Am I missing something, or is there something wrong with the settings of my workstation..? Please clarify.
- Srikar
Hi Srikar,
Cannot see what the settings of the worksheet are unless you upload your worksheet?
The enclosed worksheet image shows two inputs declared with assignment equals :=
The enclosed worksheet image shows two outputs declared with normal equal signs =
Hello there @terryhendicott ,
I`m not entirely sure if that is what I`m looking for. As you`ve asked, I`m sharing the worksheet with yah. Please go through it and let me know if it works.
Inputs and outputs assigned.
