On 3/8/2009 2:31:56 PM, Tom_Gutman wrote:
>>>V1eff^2/R + V2eff^2/R = Pavg<<
>That is incorrect. To show
>this, consider the simple case
>where V1 and V2 have equal
>amplitudes but are 180�
>out of phase. Then V1=-V2.
>The sum is identically zero,
>the power is identically zero,
>so the average power, over any
>time interval, is zero.
>The question asked is for a
>more complicated case, where
>the two amplitudes are of
>different frequencies so that
>the relative phase is
>constantly changing. Thus so
>is the instanteous average
>power. Note that "instaneous
>average" is an oxymoron, but
>yet that is what is wanted
>(and it actually makes sense).
Correct Tom I used the super position theorem incorrectly in this instance my mistake. You must first sum the two sinusoidals vectorially then find the RMS value of the resultant wave form. Your comment about the "instantaneous average" is unclear to me. By using the RMS value of the resultant, you have an equivalent DC source. As DC does not vary with time it is the average value. Of course all of this assumes that the load is purely resistive. If there is inductance or capacitance involved then the currents will be needed to be calculated as even the out of phase portion of the resultant current will produce I^2 R losses.
