I am using a matrix method for balancing a chemical equations. As a result, I get a vector x, which contains a set of non-integer numbers. Next, I need this vector is multiplied by a number Y, to obtain a set of integers. Total sum of these integers should be as small as possible.
How do I calculate the number Y?
See the picture and Mathcad worksheet in attach.
Viktor
In this case, not even enough constraints on the coefficients in the matrix "Coeffs".
Thank you, Mr. Fred!
It really works!
