Why doesn't the find function work?Those angles represent the movement of a mechanism when the handle does a 360 degree rotation and I need to calculate those in 36 positions (hence the ten degree difference). Can someone help?(beginner here)
I'll have to revise solve blocks, haven't used them for a long time, but ... Possibly because it can't an exact solution and isn't too happy with the way you've used a range variable. Change 'find' to 'minerr', solve for variable phi1 and assign to a function, then plot using the range variable.
Stuart
That was helpful but I don't know how that solves my problem.I don't need to plot that value.The values on the right are the values for phi 2 that i am looking for(in radians probably)?and i don't understand how those functions work.I'm in over my head.Thanks alot for your time.
Razvan
See attached for an alternative numerical-only approach.
Alan
Thank you. That's what i was looking for.
Razvan
