Bizarre results on symbolics with log of hexadecimal
Liv
6-Contributor
6-Contributor
Maybe I am wrong somewhere... ? (But correct results in MC2001 - see attached).
Same results in other MC versions ?
Or it's a bug of MC 14 ?
Regards, Liv.
MikeArmstrong
(To:Liv)
It does say in the help file
z must be a dimensionless scalar (real, complex, or imaginary), or a vector of scalars. For log and ln functions, z cannot be zero.
Mike
IRstuff
3-Visitor
(To:Liv)
seems to be a bug in the M14 symbolic processor, which is MuPad and not Maple.
However, I get a "cannot understand this syntax" as an error message
TTFN
MikeArmstrong
(To:IRstuff)
Same error message I get in M15.
Mike
It seems that MuPad does not know anything about hex-numbers (as it does not know anything about units).
Has nothing to do with the ln-function.
Simply try to evaluate 0ah symbolically and you see the problem.
