Cadiographie
TheodoreM.Bones
Cadiographie
Une feuille de travail tr�s d�taill�e pour les �tudes du cardiographic. Affich� dans MC11.MO
>MC11.MO
>___________________________
La m�thode "GenfitMatrix" est tr�s puissante
1. Ajuster PRNPRECISIOn 16
2. Cr�er le fichier co�fficients.
Jean
That data set does not speak much to me. We can pass a parametric spline, convex to all hulls, as fine as desired and to each column of data. Then, maybe the resulting statistics will have a stronger meaning.
I will attach the "Polyline" tool that does the fillet to the data set,
Sometimes soon.
Jean
... polyline spline attached .
jmG
Splines give me lockjaw. None of them can be used for extrapolaion, even just 1 step ahead. The complex spline you give is excellent within the data range, but I needed an autocorrelion adjunct to get some forecasts/extrapolations, etc.
By the way, it takes a considerable amount of work to scan the MathCad program & translate it into French with the miserable Glabalink (Lernout & Hauspie) program from a CD.
