by Mathcad Staff
About this worksheet:
This worksheet using PTC Mathcad helps you to calculate the force and pressure on a connection joint within the specified dimensions of the joint for a particular material, and under particular trusses and weld lengths. Given the geometry of the connector and the material properties, this worksheet demonstrates how to determine whether the force on the joint will cause buckling.
You can modify this worksheet and adjust it to fit your own needs by entering:
This worksheet includes step-by-step instruction on how to calculate for the force on the joint, the pressure on the joint, and the allowable pressure before buckling. All formulas are included along with an example and solution.
Download and explore this worksheet yourself! You can download a free lifetime copy of PTC Mathcad Express and get 30 days of full functionality.
Very Nice thanks
