Code blindness
Raiko
16-Pearl
Code blindness
Hello folks,
I have a problem with an algorythm that refuses to do as I wish - maybe it's a case of code blindness from staring to long at the screen.
I tried to write an algorythm that takes a given value from a matrix and subtracts all other values (with the exception of its own value) in this matrix from it.
I don't understand what's wrong. So if anybody has an idea how to change my code...
Thanks a lot in advance
Raiko
Remove all the 'return L' statements - they are causing your calculation to exit prematurely.
stv
Your problem is the return statement. Return causes a return from the entire expression, not just the innermost program bar. So you never get past the first value of i, as you execute a return and terminate the calculation of the entire region.
__________________
� � � � Tom Gutman
Hello Tom
thanks a ton for your hint - it works!
Raiko
