Coefficients evaluated/shown in an equation
pyoyoon
I am looking for a solution to my question, "can the coefficients be evaluated/shown as numbers in an equation?"
example)
a:= 3     b:=3   c:=7
2a (x^2) + 3b (x) - (a+b+c) = 0
can the obove be shown as:  6(x^2) + 9x - 13 = 0
only partially as far as I can see
the symbolic will give the answer you are looking for but cannot have the =0
(To:pyoyoon)
You mean like this:
What version of Mathcad or Prime are you using?
pyoyoon
(To:LucMeekes)
Thank you!  It was perfectly working for my purpose!
Actually, my equation is a bit more complex.
Your suggestion perfectly worked!
When I tried to solve the original without using EQ(), my MathCad 14 just returned the red-colored original.
(To:pyoyoon)
You can also do it the other way around: First solve symbolically, then plug in the numbers. Like this:
