Division Keyboard Shortcut Not Working
VP
Everytime I press the / key on my keyboard (which should be the hotkey for the division operator), Mathcad outputs " é " instead. How do I get it to do what it originally does again?
Thank You
10 REPLIES 10
24-Ruby V
(To:VP)
Which keyboard layout are you using?
Which "/" are you pressing - numeric keypad or "normal" part of the keyboard?
Is it a Mathcad specific problem? Does the "/" key work as expected in a word processor or in notepad?
VP
I'm just using the standard US keyobard layour. I'm pressing the normal key with / and ? on it. And yes, it shows up as a / everywhere else I type, just on Matchad it shows up as é for whatever reason.
nas0k
7-Bedrock
(To:VP)
Which version are you using? That will help narrow the search efforts.
For example:
In MC15 a ? used in a math region is the derivative shortcut, while in P3 the stroke returns just a ?. You have to use Cntrl Shift D in P3.
VP
(To:nas0k)
I'm using MC15.
And it still outputs é even in text regions.
24-Ruby V
(To:VP)
Strange, indeed.
  • Again - does it happen with either of the two / keys? (normal keys and numeric pad)
  • Is it the only key producing strange results? Try in a text region.
  • Was Mathcad 15 already working OK in this respect with that installation? If yes, what did you do close before you noticed this strange behaviour? Anything which could result in a change of fonts?
  • Am I right that on US keyboards there normally is no way to produce the character é?
Not that I would have any clue - I'm just poking around.
VP
I am using MC15 on a laptop which does not have the numerical pad, so I only know that the normal key is having this issue. As far as I can tell, it is the only key with the problem. It was working fine earlier before the issue started. It is entirely possible I may have changed or done something, but I do not know how, when, or what I did to cause this. I may just try reinstalling the program to hopefully resolve the issue. It is not too big of a problem becuase I can still use the division feature from the calculator toolbar; it is just somewhat inconvenient.
24-Ruby V
(To:VP)
Did the reinstall of MC cure the problem?
MichaelH
(To:VP)
What happens when you change the font for the equation?
What font is it currently using??
VP
(To:MichaelH)
It is either Arial or Times New Roman, but changing the font does not seem to make any difference.
MichaelH
(To:VP)
What happens when you try to type a "/" in a text region??
