Error in computing the polyroots
vveeran
Hi all,
I want to compute polyroots for the example program which I attached below.
But, I am getting some error in computing the polyroots.
Please help me to find out roots for my example program.
Also, I need to plot Real and Imaginary part of poles of the
given example program.
-MFra-
21-Topaz II
(To:-MFra-)
I'm sorry! I provide immediately. But also the F. Kolepp solution is of some merit.
About your question:
1) When looking for a symbolic solution, you have to reset all the variables and constants involved. Otherwise you will not get a symbolic result, but a numeric result.
2) That is the symbolic solution of the equation included in the "Given-Find" block.
3) simply replace the quadratic equation with the third degree where there is the symbolic operator "solve".
Bye
7 REPLIES 7
polyroots is a numeric function bit your coefficients include the LambertW Function which in Mathcad is only known by the symbolics. Thtas the reason for the error.
vveeran
Dear Werner,
Could you please correct the error of my program
and find the roots of my given program,
So that it will be helpful to me.
Thanks.
-MFra-
21-Topaz II
(To:vveeran)
I would do so, I do not know if that's what you want
vveeran
(To:-MFra-)
Dear F.M,
Thank you for your reply.
That is what I needed.
Could you please attach the code.
could you please explain,
why did you initialized like this,
gamma1= gamma1, x=x , beta1=beta1
what is the meaning of this,
ans(v)->LambertW((v^2*beta1/20)v + beta1(v)*gamma1(v)) / beta1(v)
Similarly,
If suppose I have cubic roots like,
a3(v) s^3 + a2(v)s^2 + a1(v)s +a0(v) = 0
where a3(v), a2(v), a1(v) and a0(v) are coefficients.
How to compute the roots by using the above procedure.
-MFra-
21-Topaz II
(To:-MFra-)
Bye
If you convert v from a range to a vector you can make your sheet work.
See attached.
vveeran
(To:Fred_Kohlhepp)
Thank you all
for your replies.
