Export data
ptournier
Export data
I am using Prime 3.0. I want to export data from a trace in a plot into Excel. How can I do this?
I can see one can import data from Excel, but what about exporting from Mathcad to Excel?
Thanks in advance
Pascal
(To:ptournier)
One possibility is:
You can use WRITEPRN and APPENDPRN to write successive rows of a matrix to the same output file and after completion read the data into Excel as a (comma separated) delimited file.
Thank you. I'll try to do it this way. I have to get my data into a matrix. I have defined how to plot Gain ad Phase of a complex transfer function. I only have the traces so far. I'll try to manage that before using your advise.
Pascal
(To:ptournier)
I don't have Prime 3 (but Express Prime 3.1 and 4). But I do have Mathcad 11.
You should be able to write a program like this in Prime 3 to produce a .CSV formatted file from a matrix:
(To:ptournier)
Ah, Prime (at least in version 3.1 and up) has the function WRITEFILE to write a matrix to a text or Excel file. So maybe you don't need to pragram at all.
Produces a file with contents:
"One"    "Two"    "Three"
1    2    3.14159265358979
-1    -2    -3.14159265358979
That is Tab-separated, which is also good for Excel.
(To:LucMeekes)
So probably an implementation of my WRITECSV function that better matches Prime's WRITEFILE function is:
Should anyone need this functionality in Mathcad (15 or below), it is attached.
