On 3/4/2009 3:24:48 PM, lpoulo wrote:
>I don't know how to ask MCD to
>"look for Rs*Rb/(Rs+Rb) or
>1/(1/Rs+1/Rb)," but there is
>an equivalent way that does
>work (at least on Tom's simple
>example of
>(R1*R3+R1*R4+R2*R3+R2*R4)/(R1+
>R2+R3+R4)). Let's assume you
>have the circuit and know the
>element combos in the system
>function. If R1 and R2 are in
>series, then perform the
>symbolic substitutions R1 =
>(Ra+Rb)/2, R2 = (Ra-Rb)/2. In
>terms of R1 and R2, we have Ra
>= (R1+R2), Rb = R1-R2. If the
>symbolic function depends only
>on the sum R1 and R2, then
>using the substitutions for R1
>and R2 as given, the result
>will depend only on Ra, with
>no dependence on Rb (some
>manipulation and/or
>simplification may be
>necessary). Thus, one variable
>has been eliminated, and the
>new result only has a
>dependence on Ra (=R1+R2).
>Similar transformations of any
>number of variables (2-2, 3-3,
>etc) for other circuit combos
>can be done; the object is
>that only one of the new
>variables - the one encoding
>the expected combined form -
>should appear in the result.
>This works if you know where
>you need to go, and want MCD
>to do the manipulation for
>you. It's not a continued
>fraction expansion, but I
>don't think that would lead to
>anything useful in the general
>case.
>Hope this helps.
>Lou
Lou,
I will apply this to the transfer function of the emitter follower circuit and see if it works efficiently. Thanks for your suggestion.
Mark.
