Find angle giving highest rotated vector Z conponent (around X axis)
JBlackhole
16-Pearl
To all
trying to remember my school days and the use of derivative (if that's the tool to use). Given the following
an X,Y,Z Cartesian co-ordinate system
a vector v with components (vx, vy, vz)
a rotation matrix around x-axis Rx(theta)
Header 1Header 2Header 3
100
0cos(theta)-sin(theta)
0sin(theta)cos(theta)
Is there a way of finding at which angle theta the z component is the highest?
JXB
1 0 0
0 cos(theta) -sin(theta)
0 sin(theta) cos(theta)
Here's a starter for 10 ...
Stuart
The z component of the rotated vector will be  vy*sin(theta) + vz*cos(theta)
Differentiate wrt theta and set to zero to get the maximum theta as  thetamax = atan(vy/vz)
(Check that it is a maximum not a minimum!).
Alan
1 0 0
Stuart
Thanks Stuart for the input.  A lot more that I anticipated! I can see what I need I think
No worries, JXB.
Stuart
